Hello, this is my first post on this website, so let me know if I'm doing something wrong. I am currently redoing an old pack I made when I was 15, (held together with hot glue and duck tape) to have a 3d printed case and spot welded connections instead of wires soldered directly to the cells. I finished the case, but am now trying to weld to some cells that refuse to stick. I think I understand the problem, but sadly not the solution
The interesting thing is that the negative terminal welds fine, but the positive terminal remains untouched after the nickel strip melts. I believe that the positive terminals do not have a 'tab' (still unsure about the proper vocabulary) so I can't weld the nickel strips directly to the aluminum body. Does anyone know of a way around this? Or am I making a dumb mistake? Thanks in advance,
BeanTime
Video of welding each side:
https://www.youtube.com/watch?v=ZUQYa5fN-n0
BeanTime
