John in CR
100 TW
teklektik said:Please provide a link to the source of the researched information indicating ATF turns to sludge at 100degC.salty said:I did a little research on ATF oil ...
it seems ATF breaks down above 200 degrees F or 100 C . thermal stability is important.
3. high thermal stability (so it doesnt break down into carbon or sludge)
Uh oh, I found this little blurb about Dexron III: here http://www.speedway.com/MSDSList/0130SPE012.pdf
"Carbon monoxide, carbon dioxide, hydrogen sulfide, oxides of sulfur, oxides of nitrogen, oxides of zinc, aldehydes and hydrocarbons., Thermal decomposition may produce hydrogen sulfide and other sulfur-containing gases at temperatures greater than 150 F"
Another interesting tidbit from http://www.mattscaddyshack.com/1/automatic-transmission-fluid.html
275°F is 135°C, and there's little doubt windings can quickly be pushed that high in tens of seconds in high load low rpm conditions.Automatic transmission fluid will provide 100,000 miles of service before oxidation occurs under normal operating temperatures or about 175 degree F. Above normal operating temperatures, the oxidation rate doubles with each 20 degree increase in temperature. Car engine overheating will decrease the life of transmission fluid. Example: At 275 degrees F, the fluid has a life of only 3,000 miles!
While those aren't definitive, it makes sense that ATF isn't designed for cooling off copper heating elements, which is what many transform their motor windings into by using controller settings too high. The 4000W mentioned a couple of posts up is a good example. Some rigs are fine in stock form at that kind of peak power limit, while others can be melted in minutes at even lower. Each must be tuned for its specific combination of components, loads, and use.
John
