itchynackers said:Yes, I am currently using the motocross valves. They work, but you still have to stop once (after you've heated the oil) to release the pressure. I'm just looking for the ideal solution. This is better, but not the best. I tried the pinhole method at first. It worked ok. I would get about a drop per ride coming out the cover. Not even enough to get on the brake disc. Still had to do a wipe down every couple rides though. I'm looking for a small, automatic release valve. No luck so far.
Also, I'm currently running 650ml of oil (takes a very long time to heat up the motor, and the peak temp is MUCH less). This is exactly half the open volume of my 9c motor, so the oil comes right up the the axle. I've had it squeeze out of the wires. You can actually watch it happen if you stop the bike, and wait a minute for the oil to seep. Once the motor begins to cool, it sucks back inside the axle. I thought I did a pretty good job of sealing within the motor where the wires enter the axle. Guess not. Still trying though!
whats about Gore TEX valves?
