It's 36v "20 ah" with the (rather) large (Two-tiered) BMS.
I've only been able to get 15ah out of it..
So here's what I've done so far...
Charged it up with my 36v(45v max) 5a charger till HVC kicked in...
Then ran it to LVC... (i.e. Both HVC and LVC "work").
Charged it back up and discharged to 50%.. Then did that 4 more times..
Then charged and discharged fully and still only getting 15ah..
And yes, the dimensions and weight ARE correct for the battery..
On the last full discharge (LVC kicked in), I tested (via the balance leads) each cell group..
A couple were at 2.7 and the rest were about 3.1 or so..
Once fully charged (HVC kicked in), I tested again and 2 (not the same two) were at 3.75 and the rest (the other 10) were at 3.35.. (total of ~41.x volts when the HVC on the BMS kicks in)
My guess is (obviously) the cells groups are waayy out of balance..
When the HVC on the BMS kicks in, I'm guessing it reads the two at 3.75 and stops the charging...
Is it safe to say, I should just leave the charger attached (the BMS is prolly only letting a few miliamps) for a few days to try to balance 'em out... Or should I just go ahead and charge through the "balance leads" at 3.75v 500ma each?
Or any other ideas??
