thetailwind
- Joined
- Jan 18, 2019
- Messages
- 13
Hello, thanks for your help!
I have an Ecoquip Euro 2900 ebike that I bought used on Craigslist, It has a 300w geared rear hub that I am swapping out for this hub. EDIT: Forgot to mention the original wheel is a 29", the new wheel is a 26" (shouldn't matter, but maybe it does?!)
The original hub was a tight squeeze, needing to pull the frame to get it to fit, but this hub seems to not fit well at all. Once I got the axles in the drop outs, it seems that the smallest cog on this hub is rubbing the frame. There is no way a chain will be happy on there. The hub uses a threaded freewheel. I have a chain whip and am pretty confident that the free wheel sprockets are snug but it looks like the gap between the largest sprocket and the hub itself is large. Links to pictures are below, can you help?
