drutledge
I have 3 35ah SLA batteries wired in series on my hefty cargo trike. Everything has been fine until recently, I have about 500 miles (375? ahs) on the bike/batts now.
After I take the bike off the charger everything runs well for the first 5 miles or so, about 3.5 amp hours of use. All the batts sag about the same under full acceleration, about maybe .5 volts under a 30 amp draw for about 10 seconds. Batts show at least 37 volts combined when at a steady few amp draw when riding at this point.
Problem starts soon after and it seems to happen quite quickly: when accelerating, battery #1 (+) will sag all the way down to 6-7 volts while batts #2 and #3 (-) sag in unison the normal amount. When the throttle is lifted, batt #1 instantly jumps back in line with the others in terms of voltage reading. It's hard to read while riding but batt #1 also seems to 'recharge', ie jump in voltage, more than the others when the regen brakes are active. It does not rise faster than the others though when put on my 36V 5amp charger, it rises pretty much in line with the others.
Any ideas? Batts are wired together with #10 wire. If it was a bad connection I would think it would occur from the get-go not just after a few miles of use. Would a bad cell only show itself once a batt becomes partially drained? Maybe not related but should I be rotating these three batteries much like one would rotate tires?
Thanks for any help, Don
