Alan B said:
I haven't deployed the 240W models yet. Probably will do the 6S per supply for now. We'll see how it goes.
I'm taking a fresh look at this bulk charging setup. At the moment the size and weight of these robust power supplies doesn't lend itself to installing on my CroBorg, I would rather add a few batteries instead. But I would like to have a single plug and auto-shutoff charging with some protection and safety monitoring at home and work. I may make a prototype with the 240W units since I have another working charger at the moment. Some of the design elements I'm thinking about now:
- safety grounded ebike frame (so at least 3 conductors required)
- ground isolated (uses one or more of the LED regulated supplies with adjustable voltage and current limits)
- single plug to charge (below handlebars due to available wire access)
- auto start and auto termination (plug and go, no buttons, switches, etc needed)
- removes AC power from the supplies at end of charge (solid state relay)
- use separate control power (USB wall wart)
- voltage and current sensing
- monitors voltage and current for start and end of charge plus protection and safety
- voltage, current, integrated current and time displays (LCD)
- charge time limit cutoff and integrated charge cutoff protections (amp hours)
- setup to handle 12S (50V) and 18S (75V) with one charger
- charge current 10A or 13A depending on supplies used (3 each 24V 240W or 320W HLG)
- GFCI in power cord (not essential but not hard to do)
- house in Pelican 1430 case
- delayed charging timer (requires knob/button...)(maybe)
I'm still tweaking the design, trying to keep it simple and still do the essential things. The nonessential functions must be software, if they require much extra hardware I'll probably drop them.
Concerns
- inrush current when plugging in bike to unpowered supplies - is this a problem?
