Alan B
When a cell hits HVC the charge needs to be terminated unless there is a current diversion for balancing.
deVries said:Anyway, I'm just trying to come-up with a better reason or charging scenario to use the Dimmer feature to drop the current to less than 1A vs just turning off the AC side???
Yep - the 'dimming input' does not appear to offer anything useful in this situation. Got to let that idea go as a bad plan born of posting after dinner and drinks...Alan B said:When a cell hits HVC the charge needs to be terminated unless there is a current diversion for balancing.
The not so good news is that this project has slipped off my fast-track project list and given the need to redo the layout into DipTrace it is going to take longer.
cwah said:No more controller then?
cwah said:Are these cheap power supply? Maybe worth having a link if everyone can get them at good price
dnmun said:alan, can you add in a default shutoff that would allow someone to plug a thermal switch mounted on the pack into the charge controller that would shut off the charging output when it over heated?
the old headway BMS did this by interrupting the circuit current that drove the output mosfets. the new BMS that jimmyD at headway headquarters is using actually just shorts the gate to the source on the output mosfets, very effective at turning off the output.
if the user could plug in the thermal switch at the same time they make the charging connection then your controlller could monitor the pack temperature and have default shutoff in the event over heating of the pack. maybe 80 degrees C?
Alan B said:cwah said:Are these cheap power supply? Maybe worth having a link if everyone can get them at good price
I obtained mine at $113 here:
http://www.powergatellc.com/mean-well-hlg-320h-24a-power-supply.html
Alan B said:It all depends on what one wants. This thread is about a higher quality charging solution.
There are lots of threads on Meanwell clones, and they often work well.
Those supplies don't have built-in current limiting and are not out of the box suitable for battery charging. So you have to add hardware and hack the supply, spending time, money and increasing the risk of problems.
Those supplies have noisy fans and are not potted for protection against moisture and vibration.
They don't have 5 year warranty and support from a US distributor. Hacking the supply voids any warranty they might have had.
There are many choices.
