If you have no other luck, a google search finds the datasheet in at least a couple of places
so you can then use those specs to try to match it manually at those websites. PITA but at least is possible.
The main things to note are
--it needs to be at least capable of the same VDS or higher,
--at least the same IDS or higher (drain current)
--max of the same RDSon or lower (drain resistance) to keep temperatures low
--needs to be the same gate control voltage (VGS) range. Some FETs are analog 0v-15v (or whatever) control, and some are digital 5v control, and just turn on or off.
--needs to be the same package (like TO220, TO252, D220, etc)
Any other things that can be kept the same are good, but can be different and still be usable in most cases.
