j bjork
They look like this:
The endplates are rather easy to get off, cut in the welds.
There are plastic in most directions underneath, so there is some room for errors.
This is what you will find underneath.
Here I have cut off the top as well.
The first cut I did was in the rounded corner between the top and side, dont do that..
A cell is right under there.
Instead cut in the top, a little bit in from the side.
There is plastic between the top and cells:
In the bottom there is a hard, putty like thermally conductive substance that seem to stick very well to both cells and alu case:
Between the cells there is a pretty tough glue as well:
I think it might be possible to slide the whole package out if you could dissolve the blue, thermally conductive stuff.
Then you only have to cut the ends of, that part is not too bad. The other cutting is pretty dangerous I think.
The question is how to dissolve the blue stuff? And also the glue between cells.
![c8VAsAR.jpg](/sphere/proxy.php?image=https%3A%2F%2Fi.imgur.com%2Fc8VAsAR.jpg&hash=b7a5b139313cb34dc30210b58174d83c)
![sqUA5g0.jpg](/sphere/proxy.php?image=https%3A%2F%2Fi.imgur.com%2FsqUA5g0.jpg&hash=e18972e3fa2fbfcfa0414301dbe1bb5a)
![dAFMmxM.jpg](/sphere/proxy.php?image=https%3A%2F%2Fi.imgur.com%2FdAFMmxM.jpg&hash=a6d4e1be551254ea93e8cef99a4d602f)
![XbXrq7M.jpg](/sphere/proxy.php?image=https%3A%2F%2Fi.imgur.com%2FXbXrq7M.jpg&hash=b8cc88d28c9191d91eb3351520dc3045)
![Mz6x6eg.jpg](/sphere/proxy.php?image=https%3A%2F%2Fi.imgur.com%2FMz6x6eg.jpg&hash=6d77ff2a9b0f26c96b33b50c54da4ee9)
![ktg3weF.jpg](/sphere/proxy.php?image=https%3A%2F%2Fi.imgur.com%2Fktg3weF.jpg&hash=2a21550e4677f5dd0b09fe68f12c4050)
