The eZee has thinner laminations, which produce less eddy-current waste-heat. that may not sound like much, but geared hubs have a 5:1 ratio between the motor RPMs and the wheel RPMs, so a 360 RPM 26 inch wheel at 28-MPH would have a motor spinning at 1800 RPMs.
If thinner laminations help on direct drive hubmotors, they help 5 times as much on the geared hubmotors.
That being said, you can take the cheaper BPM geared hub, swap-in fatter phase wires, add ATF while sealing the sidpelate edges with goop, add a tiny sideplate vent, use a sensorless 12-FETcontroller...and it will likely run on 2000W fairly reliably.
https://endless-sphere.com/forums/viewtopic.php?f=16&t=51237
