Parts List Help EMB
Barnsieboy
Hello Everyone
I have recently got my hands on a cheap MBS razor. I only bought it cause I wanted to motorise it. Now I have been struggling to find a solid parts list.
Essentially I am after a list of electronic parts I could order and slap the beast together with. I am after a single wheel drive setup (open to recommendations would need to go up a 15 degree hill) to try and keep the build simple as it is my first one. Any help would be greatly appreciated. Keeping it as simple as possible would be great! The board itself is quite old but still really solid.
Thanks in advance and cheers for all the inspiration so far
For your consideration:
Motor SK 6365 or SK 5065 or some Alien 50mm or 63mm motor, but maybe better 63mm if it's for mountain board with single motor.
ESC 6 cells 150Amps Hobbyking or Hobbywing or similar or Alien controller for more than 6 cells
HTD or T5 pulleys, depending on what motor and wheels you’ll use and belt for it.
Batteries Flymax 2 x S3 5000mah (20C, 25C, 30C higher the better)
In case you would go dual motors at the end than i would suggest to go with single ESC (single for dual motors) from alienpowersystem. People write that these ESCs are alright and i like idea to have one ESC for both motors. Never tried Alien ESC but i hope it doesn't have cogging and starts smooth with other proper parts setup. But then again when you go dual motors price goes up.
