I want to add a motor to my existing mountain bike to assist (or augment) my peddling. Peddling will always be my main drive source. But my new location has many steep hills, mountains, and it is too much work to just peddle.
First I thought a mid-drive motor with torque-sensor was the way to go, but thanks to feedback from this forum that solution is a bit too expensive and complicated. The recommended alternative is a hub motor with a cadence sensor. But I do not want a throttle, like would be typical on a motorcycle. The reason I don't want a throttle is because I usually ride hard on the handlebars and would be pulling on the throttle and inadvertently increasing or decreasing throttle.
Instead of a throttle is it possible to have a similar mechanism as the thumb derailer control? Meaning a thumb lever that when pushed would click to different levels of motor acceleration. For example when starting out I could push to position "1" that would be low power, and incrementally push to higher position as more power is needed. If I had this kind of mechanism I feel I would not need a cadence sensor, as I would add motor power when I wanted it.
In terms of motor size for a front wheel hub motor, I weigh about 175 lbs, and as I mentioned would be going up pretty steep hills. I don't know how to classify the steepness of the hills in terms of degrees to give you a better understanding, but they are steep enough that it is a real hard workout just to go up them. So, I am looking for a motor that is powerful enough that it would make riding up the hill equal to as if I was riding without any motor on a flat road. Would 500 watts be enough or...?
