Phaserunner, cycle Analysts alternatives
I have bought two asi 855, these controller is perfect.
Setting up an ASI is a pain, if you don't know, what you are doing. There was a great knowledge base directly from ASI available online in former times, now all this information is only available for OEM customers with an ASI account.
I don't know, if there is a hack to get free access.
There are some open source projects, that describe the parameters, but this information is not useful for a newbie ;)
I will ask to mine seller
I saw that everything available is, to modify for bafang motors.
it's an new controller for me.
Normally you can connect the asi controller, download the software.
Are their different bafang configurations, I don't know.
And if they don't give parameters for the different motors, then I send the controller back.
I found usb cable.
On the website to sell
Everything is included to get it configured via the official BACDoor Windows software, there isn’t built in bluetooth so the login credentials are not needed. I have also included the USB to Serial driver.
Can't find it. Please give link.
The link is in the post. Maybe your web browser does not show it?
Here is the link again
Here are the links with files
Company from Italian. After two days arriving.
Hm, it must be an old system, for the recent PC BacDoor, you need an ASI account:
Even the old version should not be used by end-users but only by experts, who know what they are doing ;)
BACDoor® PC is designed to give users the complete ability to adjust all the controller parameters and functions directly from their computer. Due to the amount of low-level access to the controller this app gives, it is NOT provided to end-users.
Could a end-user become a expert by learning how to control a controller
You would have to learn a lot about FOC control and peripheral signals like PAS, torque... , to understand, what is the meaning of each parameter. The problem is not magic smoke, as the ASI has many safety measures. The consequence of this measures is, that the controller will jump into fault mode easily, if you set something wrong. And you will despair to find a setting that doesn't end in the fault mode. I guess this is the reason, why ASI doesn't support end users any more.
I have no bacdoor software.
Start program up, ask for credentials.
Ask to asi, answering 500$ for one year, then 100$ an year for use of bacdoor software 😀
And what documentation is there?
If the configuration for bafang is available, maybe.
Anyone know this software?
Or Crack? Or login code?
Then can test it.
Want the controller tested before I decide stay with grin or go further with asi?
Give asi help, or do they no answering like grin.
Found the software and cables.
Are there configuration for the bafang motors in the bacdoor software or need to start from scratch 🤔?
Received the cable and software.
I saw that it's with coding xml files.
I saw xml file for bafang bbshd.
Not sure it works, because of different versions
So I start new thread about asi bac 855
I saw also vesc controllers, try first asi.
Program the controller looks the most challenging aspect for the controller. How to start?
Received bacdoor software but it's old version 1,
Have someone the new version.
I ask help or documentation on producers, no answering.
So terrible companies asi and grin technologies. Both Canada.
It's look like EU have to start to produce everything themselves.
Buth here also bad politics and stupid governments 🙄.
Can't start e-bike company, don't want to work for stupid politics.
Also Don't find bacdoor software on usenet.
Not Helping customers is the new world 🌎 😒. And ai can't help me I think. 😅 Don't think you shall find happiness only with money.
Anybody have 3d info for made diy case for bac controller.
I have searched on German pedelec forum, and find some good information
Asi and phaserunner have the same source software
And the other is vesc.
Vesc is open source and asi bacdoor is closed
Flipsky vesc controller 80$ hopefully it's working a long time
Before bacdoor was open and now closed
All these different versions also make it very difficult
And information that are given is illegal
I think I say goodbye to Canada and is China that wins.
Do you really need open source controller if the not open source controller allows you to change the parameters anyway? Do you know how to code?
I have 3 different motor models, I read that the parameters in the bac855 are 👎
So I don't think that standard parameters will work. Different screens and so forth.
I send the asi controllers back, where they belong garbage.
And shall try vesc controllers cheaper, open source software, specific vesc forum and project website.
This asi and Canada project are for me past.
Could a end-user become a expert by learning how to control a controller?
If it smokes? You got a problem.
Sure some can become experts Most can not. Find a setting you want to change, find out what it does, document the setting. make a change document the change and the result. If you change more than one at a time you will not learn and become an expert. Most can not do this.
When all information is differentiate and old and not accessible then you have a lot of work
Everything can be done, but need affordable
I saw these video about vesc, and everything you need to know for starting with vesc controllers
I saw controller software/firmware
First I thought it was like android structure,
But it is in lisp
Lisp (historically LISP, an abbreviation of "list processing") is a family of programming languages with a long history and a distinctive, fully parenthesized prefix notation.[3] Originally specified in the late 1950s, it is the second-oldest high-level programming language still in common use, after Fortran.[4][5] Lisp has changed since its early days, and many dialects have existed over its history. Today, the best-known general-purpose Lisp dialects are Common Lisp,
All vesc controllers work with lisp, I 🤔.
