StevenR
I bought a Ping v3. It rocks at 35A+ continuous with no trips and minimum voltage indicated on the CA is about 49 volts with maximum of 1825 watts indicated and a 43A maximum. I will solder my shunt to get to 60A continuous after I break it in a bit (20-30 cycles is a target but it may actually be more before I get around to it) although 35A+ on a 5303 with 48V35A controller is almost enough - 60A may be overkill, except on accelleration and 5 second bursts are hardly continuous. I have 6 cycles for 60aH with the maximum discharge less than 10aH. I had to use it before it fully charged for the first time and ran it up and down 4-5aH once or twice before I fully charged it and let it balance overnight. Now it is basically on charge/balancing or discharging 24/7 for the next several months (until the snow flies and perhaps even thereafter) and I will monitor the cell voltages compulsively.
Better packaging. Shrink wrap even! The BMS is in a transparent shrink wrap tube with the charge FETS covered in blue. It came taped to the battery with clear packing tape and I haven't chaged that yet even though there are ugly little bits of styrofoam under it in places. The battery itself is shrink wrapped with plastic end covers under the wrap. Output wires are heavier than the v2 - 10 gauge versus 12 gauge, perhaps? I will post better pictures shortly.
New v2.5 BMS seems to balance effectively, if slowly. Most cells are at 3.79-3.80 volts on CV at 61.09V with a Ping 5A charger. One is at 3.74 and has come up from from 3.68 over the last few hours. I will watch it as I do laundry over the next couple hours to see if it comes up to match the others but 0.05V isn't much difference. Everything seems to be stabilizing nicely. The LED's are a nice touch and give a great sense of confidence that everything came up properly. It came with the charge leads seperate from the discharge leads (no common positive) with the charge plug attached. Charge FETs got quite hot at 3.5A. I will see how they do at 5A.
It was $798 with 5A charger plus $130 shipping. v2.5 is $598 with 2A charger plus $125 for shipping.
BTW: I have about 2300 miles and 300 charge cycles on a Ping v2. My Ping charger had too low a voltage (58.2V CV) so I set my Soniel the same. It never properly balanced. By the time I figured this out and reset it to 61 volts, it was sick and then one cell group went to 0.0 volts. Three or four others are at 3.3 volts. If I put a single cell charger on those cells they come up but then droop back to 3.3 over the course of several hours. I am replacing the one 0.0V bad group then will do a capacity test. I may do individual cell capacities first but I only have a 1A discharge Tenergy unit so each test will take a while. I have a total of three new cell groups and want to replace the worst existing ones. This will be my backup bike battery and will be split into two 24V 20aH packs for use in experiments like 90V screamers and great big parallel packs - Headways are on the way as soon as the boat docks.
