Bazaki
- Joined
- Dec 25, 2009
- Messages
- 639
Hi there,
I've been reading alot the last few weeks about different kind of packs.
My mission is to build an Electric outboard with 15KW to get in plane with a inflatable boat.
I want to use following setup :
http://www.plettenberg-motoren.com/UK/Motoren/aussen/Predator37/Motor.htm 1000 euro
http://toprc.eu/jeti-spin-300-opto-d 500 euro
8x Turnigy 6S 5000mah to make one 12S 20ah 570 euro
Second hand broken 10HP Yamaha outboard 200 euro
But I want to sail this boat with my wife and daugther also and putting so many Lipo's together could be dangerous. Although I would store them in a metal case which can be thrown out of the boat.
I choose the Lipo because they are very cheap and I have really good experience with them, cheaper than A123 ( I think )the problem is the charging, to buy several good chargers a 1000 watt power supply would cost about 1000 euro. And a lot of work to charge each single pack.
As a "project" it's fun to watch and monitor Lipo's being charged but as a daily used boat to go out with the familiy it would be nice to have a plug and play battery pack which is easy and safe to charge and handle.
I have seen affordable 48v 20Ah A123 packs, but usually with a BMS that handle only 100A (totall pack).
And my theorie was, if a Lipo will be dead, I can replace it, if I have a stock A123 48v 20ah pack and 1 cell is dead, how can I replace this one cell ?
I'm looking for some advice, just to let you know, I don't want to sail on 15kw the whole time, just use it sometimes. 5kw will be enough and only for a few minutes.
Any other ideas for my setup maybe ? I didn't order anything yet !
Thanks !
( EDIT ! : With the A123 packs, I just mean a stock 48v pack, other kinda brand is also fine, as long at it is a safe pack )
Thanks !
