He there! My name is Vadim and I ordered a Chinese 8000w 40Ah bike some time ago. It was all great, I was going back home after I have done 73 km on a single charge and I nearly drained the battery. I decided to accelerate full throttle and the battery died. I pushed the bike back home for 1 km and it refused to charge anymore.
I contacted the supplier and they tell me that it's definitely the BMS. OK! I took it to the repair shop to check the issue and received the letter from the repair guy:
Before ordering a replacement BMS with the same parameters, my husband checked all the components and found the following problem:
The battery consists of Panasonic NCR1865BD cells in a 20s13p configuration. According to the NCR1865BD cells specification, the maximum capacity is 3180 mAh and the maximum load is 10A per cell. This means that the battery capacity is 72V/41.34 Ah with a maximum possible load of 130A. This battery is completed by a BMS for a maximum current of 100A. A controller with a maximum current of 150A is used for the 8000W motor.
This means that the battery with a 100A BMS is not able to supply the necessary current for the motor and a 150A controller under load, which can lead to disconnection or damage to the BMS. It would be possible to add a more powerful BMS to the battery but not more than 120 - 130A, which is still insufficient. A more powerful BMS cannot be used in order to protect the battery cells that are capable to deliver a maximum of 130A. Under a load above 130A, the battery would overheat, reduce the life of the cells, and possibly damage them.
This motor and controller would require a battery that is capable of delivering at least 150A under load. Replacing the BMS with a new one would put the battery into operation, but it is possible that the BMS would be damaged again at maximum load and for this reason, we cannot assume liability for this repair.
So, the manufacturer provided an option to send 160A BMS to solve the problem and the repair guy said that 160A will kill the battery and that bike might catch fire.
Please give an advice what to do!
