jmjm1
100 µW
Hi:
I have a serious problem with my 2010 ZERO DS and I do not know what can be the solution.
The bike was first launched in 2012 and has only 1,500 miles.
For months ago, I washed the bike with a water pressure machine. I let the bike dry two hours. After the bike ran for 5 miles and then the electric motor did not do work. The motor was stuck by a broken brush blocking the movement of the motor armature Agni 95R. I turned off the bike and relit three times. At first, the bike lit sounded "beep" all ok BMS. The instrument was turned on but the motor would not turn. The third time I tried to turn the motor, the bike system is turned off, and for 6 months has not been turned on again. Now when I put the ignition key to "ON" sounds "beep" of the BMS ok, but after the instrument panel no lights, nor the red light that indicates the error code lights.
I measured the voltage of the 14 cell battery pack and each shows 4.1 volts. The entire battery pack is 57.8 volts. In theory, the battery pack is 48 volts and the rated voltage is logically higher, so I think, although I am not an expert, that the problem is not with the battery pack.
I just noticed another motorcycle (motorcycle works perfectly ZERO S 2011) in the event that there is any broken or malfunctioning component normally comes power to the instrument panel and a red light to indicate the detected error code by the brain of the bike (BMM) by the number of flashes emitted.
I have also observed that in all cases there may be a problem in the system of the motorcycle, for example, a problem with the engine temperature sensor, or a problem with the throttle or low voltage battery pack, it may be that the instrument panel does not light (for low voltage battery pack, for example) but always, and in all cases, the red light on the instrument panel indicating the error code detected by the BMM. In all the above cases, if there is an error code, the contactor does not jump.
My problem is that the instrument panel does not light, but also no red light error code lights (With the DrBass help and tips I have learned to checked the voltage of the battery pack, the contactor, throttle, controller, DC-DC converter). All these components are tested and working properly. It is like if any form of energy came to the Instrument panel (Dashboard).
The motor 95 R agni is repaired. It is a pack of 8 new brushes and a new toothbrush holder with a new engine temperature sensor purchased with the kindness and help of Steve from JozzTeck. The engine now turns perfectly with an external power (12 volt battery).
I also checked on the bike to work (ZERO 2011 S), never skip the stator until the instrument is turned on, it performs the test that everything is correct and no error code lights, only then, is when the contactor jump and the controller allows to rotate the electric motor.
Based on the above observations, I conclude that we should focus on diagnosing the fault of my ZERO DS 2010, on the question of why that red light on the instrument panel, which reports the detected error is not lit, because that is the prelude everything else to work.
My thoughts on the matter, now that the problem might be broken the instrument panel, and for that reason, the red indicator light on the error code is not illuminated. The other possibility is that the BMM is broken.
I do not know if there is a method to verify the correct operation of the instrument panel. I do not know if maybe there is a fuse inside it or not.
Please, I need your help, suggestions and opinions about my problem with the 2010 ZERO DS.
