Doctorbass
Time for sharing a great idea for when it come to test battery power and energy at high rate !!
[youtube]u-qo6sjzS-Q[/youtube]
Doc
Doc
excuse my ignorance, but is there an advantage of using the hairdryers over a bunch of electric kettles?
no matter if you use hair dryers, kettles or hot water systems. they are all ohm's loads. therefore you can input DC and use them as load.would a standard electric hot water system be compatible in order to reuse the heat created?
Cowardlyduck said:Great stuff Doc!
You should make something useful from them also...why not make a super awesome snow blower/melter. :lol:
Cheers
Doctorbass said:Cowardlyduck said:Great stuff Doc!
Cheers
Yeah.. in fact i might try making a Dyson style quick hand dryer lol... but i'll need 130A on 120V or 65A on 240V lol!!!
Doc
Doc
Takemehome said:I would like to see the face of the seller when he saw your head.
Ten hairdryers ?
Really ?
For you ? :lol:
all that i have DO. easy to test. just cover the input/back side with your hand so no air can go in. the thermoswitch will engange within seconds and turn of the hairdryer.brumbrum said:Do hairdryers have a built in cutoff when they get too hot or are left on for a certain period of time?
Many of them do not have reset able thermal switch, they have thermal fuse. In case of fuse it is 1 time experiment. :lol:izeman said:all that i have DO. easy to test. just cover the input/back side with your hand so no air can go in. the thermoswitch will engange within seconds and turn of the hairdryer.brumbrum said:Do hairdryers have a built in cutoff when they get too hot or are left on for a certain period of time?
Overclocker said:![]()
inside the dryers are coils of nichrome wire. so skip the dryers and get nichrome wire. so easy to build HUGE loads
