Alan B
I've converted a number of ebikes with trapezoidal type motors to Sinewave Field Oriented Control. They run better on sinewaves in terms of noise, and the controllers have been more reliable than the simple trap controllers that don't really measure motor current and in some cases occasionally have excessive current peaks that damage the FETs. Motor current throttles (torque) which are generally found only on the FOC controllers are also much more driveable.
Trap controllers don't rotate fields smoothly like sinewave FOC controllers do. This leads to small reductions in efficiency as the rotor is not always perpendicular to the magnetic field. Shape of the BEMF waveform itself is not really the issue. This has been measured and documented with various motors in the thread on the Compact FOC controller from Ebikes.ca known today as the PhaseRunner.
https://endless-sphere.com/forums/viewtopic.php?f=31&t=65031
