Hi Guys,
Here is for the very first time a picture of my DH Comp (version Coupe de Ville - NO OFF-Road, I use this type of frame because I am pretty heavy) it is in progress for electric conversion...
Frame = Giant - DH Comp 2004
Rear suspension = Manitou Swinger SPV 6 ways (8" stroke) adjustable with 450Lbs coil spring
Front fork suspension (double crown) = Marzocchi Bomber Junior T (7" stroke)
Seat post = Easton Havoc 30,9mm
Seat = Serfas E-8000, E-Gel Cruiser
Stem = Easton Vice
Handle bar = Easton EA70 Monkey Bar
Handle Grip = Megasoft Ergotec
Headset = FSA The Pig DH Pro
Rims = SunRinglé Double Track 24" X 36 holes (ERD 476mm)
Tires = Kenda Kraze 24" X 3,00" (Road tire)
Tube = Extra thick tube 24" X 3,00"
Anti-puncture membrane = Mr Tuffy (27242691780)
Front wheel hub = SunRinglé ABBAH SOS DH - front hub 110mm with sealed bearings
Front spokes = DT Swiss
Rear spokes = NewsonSportec 130mm X 13G (custom made)
Chain = Shimano Deore HG53 (9 speeds) with extra lenght
Rear Derailler = Shimano Deore XT (RD-M751 SGS)
Right speed shifter = Shimano Deore (SLR-440)
Cassette = Came with the Hub-motor (7 speed 11-32T Hyperglide)
Bash guard = Black Spire AS-1
Pedals = RAM/Truvativ Hussefelt
Disk brakes = Hayes Mag 9 with 8" rotor and adapters
Lugage Rack = Arkel Randonneur
http://endless-sphere.com/forums/viewtopic.php?f=3&t=37808#p550719
Lugage Bag = Arkel TailRider
Front Fender = Topeak Defender XC1
Rear Fender = Topeak Defender XC11-29er
http://www.topeak.com/products/Fenders/defenderxc1_xc1129er
Blue LEDs wheel light motion install on the tire valve.
Conversion items:
Torque Arm (damageless) = My own design on SolidWorks (machined on Hardox alloy) see topic
http://endless-sphere.com/forums/viewtopic.php?f=2&t=32014
Electrical monitoring = CycleAnalyst Ver2,3, CA-DP (large display)
Hub-motor = Crystalyte rear HT
Controller = Infineon Controller 24-48-60-72V (65A) EC124110SL-MKII-LYEN EDITION-12 FET 4110 MOSFET Mark II sensorless controller
Throttle = Half-twist (standard model)
Cruise Control = Crystalyte (standard model)
Speed Control = L-M-H switch (standard model)
Lights LED system = Front MagicShine MJ-816 (1400 lumens) / Rear MagicShine MJ-818 (3W) including Li-Ion pack and charger from BrightStone Sport Inc.
http://brightstonesports.com/
Temperature monitoring = Maverick ET-808C (BBQ heat sensor... got mine from Canadian Tire 085-2086-2)
Additional handle bar bracket added in parallel to the existing handle bar to install all the accessories and free some space...
http://endless-sphere.com/forums/viewtopic.php?f=2&t=38705#p565053
Cell pack and Controller:(to come)
Voltage = 60V / 15Ah (72V is coming)
Cells = Headway 40152S (20S1P)
BMS = (to come)
Charger = Soneil 110-220Vac / 60V @ 6A
Safety devices = Quick cable 39101 disconnect main switch, emergency push on panic switch, built-in fuse in the cells pack and ON-OFF key switch...
Type of cells enclosure = homemade case made of PVC foam (cell pack and controller housing).
Optional project = I might later on use a mini LCD display 4,2" to build some kind of real time cells monitoring to install on my eBike
http://www.4dsystems.com.au/prod.php?id=155
Have a good day...
