Powering 80V lawnmower with non-stock battery
I use Makita 18V (5s) batteries to power any brand tool, ebikes and anything else needing DC power. I've replaced a heavy old gas motor on a high end front throw reel lawnmower with early Currie brushed motor (free) and it's a perfect close cut machine for bermuda. I have tons of experience building and repairing ebikes and etandems, their motors and controllers.
I have a need for a sturdy rotary mower to control weeds at a rental with a large lot. Harbor Freight has a decent looking 80V (20s) Atlas brand machine; cheap. I'd planned to power it with 4x18V Makita's in series (20s) since I have many. A simple 2 wire 81V connection, 4 Makita's in series starts the mower fine, but cuts off after a few second burst. The troubleshoot page says the motor will cut off if overheated so I assume both battery and motor are protected.
Makita 18V tools connect to only 2 pins on the battery (+18V, ground). The Atlas battery is dual voltage (40/80V) and has 7 pins slots. The 2 outside are 80V/ground and connect to the controller, the next 2 toward center are 40V/ground and not connected, the next 2 slots have no pins. The center pin is connected to the controller and I assume monitors battery temp via a thermistor.
I don't have a Atlas 80/40v battery so I can't open to verify the center pin's function. Makita's battery thermistors are ~24k ohms at 70F. Another brand I have is ~11K ohms at 70F. I substituted a 50K ohm variable resistor and tested about 25 different resistance settings. The results were always the same; start then off.
Any suggestions to make this mower work with a non proprietary battery? Or other test to try? I could buy an Atlas battery to return after looking inside, but that doesn't seem exactly fair. I could probably also run the motor using a ebike controller but an expensive Makita mower is probably a better choice.
BTW, the Atlas Brushless 80V brushless motor is wired just like most ebike motors. 3 phase wires and 5 wires to the 3 hall sensors. The controller is fairly standard with 3 throttle input wires and 2 other wires I assume to the start switch. It has bays for two 80V 4ah batteries which are automatically switched via 2 relays. Both batteries are never used together and the manual notes there is a brief delay during the switch.
The issue with your 80V mower cutting out could be due to how the Atlas battery communicates with the controller. It might have specific safety features or signals that your Makita batteries aren’t replicating perfectly. You could try adjusting the thermistor or adding a dummy load to mimic the Atlas battery’s response. If that doesn’t work, investing in an Atlas battery might be the best way to ensure full compatibility.
