waynebergman
Tom I think liketoride is saying he killed a computor not his controller?
tommie said:No way programming your controller will have `killed` your PC,
maybe crashed it but certainly not killed it.
Not sure if that could happen indeed, although one of the wires has the full battery voltage on it. Not sure how an USB port would react to that.tommie said:No way programming your controller will have `killed` your PC,
opperpanter said:Not sure if that could happen indeed, although one of the wires has the full battery voltage on it. Not sure how an USB port would react to that.tommie said:No way programming your controller will have `killed` your PC,
works great on Mac with Virtual Box. I use and old XP disk I had. But if you're going to get into battery building and battery testing, a Windoze laptop make sit much easier. The only folks catering to Mac are GrinLeebolectric said:I'm guess I'm going to need to buy a cheap PC Laptop just to program this thing...
...unless someone has a simple way to make it work on my Mac...?
Anything I need specifically for the laptop? ...just any with a usb port?
What kind of laptop would you buy, if it was pretty much for this purpose only?
I'm looking at options costing less than $50 if possible...
...it doesn't have to be awesome, just get the job done and not kill me with frustration.
Which operating system works best with the programing?
windows 7? ...or 8?
I have the cable coming and will be following the ElectricFatbike guide.
What did you end up doing?Leebolectric said:That was quite painless.
For a Mac user like myself, trying a PC for the FIRST time ever...I expected much worse.
Thanks for all the tips everyone, you rock! \m/ \m/
Which computer?Leebolectric said:I followed the em3ev settings mostly.
Full throttle in all PAS levels.
Slow ramp to go easy on the hub.
Nothing experimental on my end, just following instructions.
Seems to work perfect, lotta power now.
