Hi
I just bought a bike with a Bafang Max middrive, and was just curious on what options I had to program this (mostly to get any sensor data out). But I found no information on the serial interface and if it's compatible with the software out there to program bbs01 and bbs02.
Then I found out that Bafang has their software that's used by the assembler/manufacturer/dealer freely available on their webpage under the download section. Using it after you install it however requires an account that one can get by requesting one from them, but I suspect this is only for registered dealers (duh).
Well, not anymore. I wrote a really small python script that spoofs the login response of their server, letting one access the programming tool in the BESST software (tested with v1.06). For this to work you need to add the line "127.0.0.1 besst-api.yuntick.com" to c:\windows\system32\drivers\etc\hosts . This will redirect all communication intended for the bafang servers to the local web-server run by the script. Any login will then automatically be accepted. Open notepad with administrative privileges to edit this file, or save it somewhere else and copy and overwrite it afterwards. Then start the spoof.py if you already have python installed, or spoof.exe if not. It might need some microsoft visual c++ redist package, but most computers already have this installed. Login with whatever email and password you want. After login click menu and then tool. Just to clarify, this does not give you access to any restricted Bafang servers or anything I would consider shady, it just let's you open the software that runs locally on your computer.
An diagnostics mode is also available if one modifies the python script (type from 4 to 3 on line 19), which should do some testing of the display and controller.
As I have no programming cable I have not tested this. Since the software comes straight from Bafang I wouldn't expect it to put your bike on fire, but then again don't blame me if it does. If anyone want to test it out it would be interesting if you could share your experience.
