ebkr
Just figured out the best replacement for the standard wiring of SLA batteries. Instead of standard AWG10 or AWG12 wires it's much better to use AWG8 speaker wires. Those can be picked at only $1 a foot in surplus stores. If they fit in your battery case you'll see much less of the voltage drop. For main power wires I use AWG4 speaker wire. Those aren't easy to solder, but you can just crimp them. Speaker wires are much softer, then any other type of cables I've worked with and don't brake that easy at terminal's crimping.
