I'm new to ebikes.
My issue -- before purchasing , contemplating getting a Biktrix ultra fs pro.
Comes with a bafang m620 mid drive and 11 speed rear cog.
What would be the upper speed limit of such a drive combo without the governed speed restrictions programmed in
I'd like to be able to go faster than the 28mph advertised in throttle only mode.
My communication with someone from that company said not doable. Is it ir isn't it? Or maybe I need to build my own?
I'd like to have an upper limit 45-50 mph
Cruise at 30-35 mph
Range 75-100 miles
Weight 185 lbs
Budgets no issue
Skill level -- worked on aircraft 15 years, currently electronic tech on light rail vehicle mass transit
So I think assembling my own wouldn't be much of an issue.
Are new bikes easy to reprogram or if I have to DIY my own il would like to purchase a dedicated frame that accepts a bafang mid drive m620 . I DO NO WANT TO DO A CONVERSION.
If there's substantial savings on a DIY I'd like to do that
Advice pls
Cruise at 30-35 mph
Range 75-100 miles
Weight 185 lbs
Budgets no issue
Advice pls
