garman1987
- Joined
- Nov 26, 2014
- Messages
- 16
Hi, can someone help me? After trying a classical 36v 250w controller on the bbs02 750w 48v motor, i have found several problems:
-Controller gets hot quickly without load
-Motor makes a strange vibration when turning on the throttle at 100%
-General speed is too low in my opinion, even considering the battery measured voltage is 37.5 v instead of 51-53 v
-Led display is not able to regulate the 3 assistance level (i'm not using a PAS sensor and i think this is the reason for that)
What i need to understand is:
-Why 36 volts generate this vibration
-Which 48v 500w controller (20 A current on plate) could ensure the perfect work at a good maximum speed
Many thanks if anyone can help me.
This is the video : https://www.youtube.com/watch?v=cOzoyzLUfC8&feature=youtu.be
