MadRhino said:
DogDipstick said:
Are we talking until the first failure from new? Or are we talking irreparable?
I got a little 35H 205 V1 and it lasted 720~ miles under some good torture. +150C temps > 50% of the time. Hall failed.
Slapped a new set in, away we go. Repairable. So 700mi~ @ about Rollback set <150*C. Hard cut at 190*C Halls limit was somewhere round 150* C. I think. The halls the hub came with.
I have seen pics ( IDK wut yall do to get them that way) that look like burnt charcoal. No fixxing that. Since, i have lowered both the rollback and hard cut.
Yeah, but we are talking about the QS205H50v3, that is another animal. Much like to compare a dog and a horse.
Is it? Same magnet composition and same factory, I was presuming.. same connectors save the big ones, same pvc insulation... , and same shape and size,,... same thermister.. same hall sensors that they have in the stock at the moment, same font on the hub... Copper and enamel, probally came off the same roll... the spacers and stator insulation from the same supplier...
yeah alu core and extra 15mm depth.. but .. much more similar ( to each other, the QS205V1 and the V3) than a Crystalyte from Grin or a BMC or many of the generic something like that...
Been studying different manuf styles... as of late. I honestly shove 8Kw in and get 3.8Hp out. My lil V1. I know that isnt "QS 3KW" numbers.. but .. the over volting and heat are similar..
Yes I know the diff... but in my simple juvinile mind I figured they were somewhat similar, comming from the same horse-dog, or dog-horse, or whatever you called it...
with all the experience you have... Thanks for the correction I would never get over my newbness without ya....
Duh. Lol . What a dumb animal this dog is. Honestly I have seen horses scoff at dogs. Now I know why. Ty.
Fact is I had a 2018 hub, bought new, under the QS label, and figured Id abuse it till something broke. Well, Im here to tell you what did, the Halls... in 720 miles of over 150* over 50% of the time.. .
Or do they have different Halls? Different Magnet composition? Different bearings? different glue? Different Thermistor ad all that different everything? LOL I honestly doubt it, but correct me if the only differences are NOT primarily the magnet depth and the core composition.... please. I presumed that was pretty much it.
LOL same friggin axle from the looks of it... but this newb aint for sure. Same little shitty tq plates and double nut. Same bearings.
Thanks so much for the correction, Rhino. Dont know what I would do without ya.
No, they were not Honeywells but yea from the data I found they were rated to the 150* i think.
Rhino? Have you had both? Both the Horse, and the Dog, models of this animal (motor)?
I assure you I will.
If you dont know Ill find out then but thats kinda why Im here makin a tizzy too.
I want to know. What did you see different? ( aside fromt he obvious... 35H vs 50H, and the core compositions.. 2 sets of sensorbanks) ( like sensor, magnet ,bearing, axles? different? I implore... )?
Looks like a Doghorse to me, and or a Horsedog. If you ask me.
