QSMOTOR,0.5-12kW Electric Hub Motor & Mid Drive Motor Manufacture China
QSMOTOR said:
New QS 3000W Mid Drive Motor with gear and chain
For the this, we will custom alex to add a gear like below picture:
So you can use this powerful mid drive motor on your e-bike or e-motorcycle.
Specification about this motor:
Item: QS Motor 3000W 138 70H Mid Drive Motor
Motor Type: BLDC Permanent Magnet Inner Rotor Motor With Hall Sensor
Brand: QS Motor,QSMOTOR
Motor Design: Single axle
Matched Wheel: Any size
Magnet Height: 70mm, 40pcs, 5 pole pairs
Diameter of stator: 138mm
Rated Power: 3000W (peak power, pending)
Rated Voltage: 72V as default
Speed: 100KPH
No-load rpm: 3800rpm without flux weakening, 6000RPM with flux weakening.
Max Torque: approx 56N.m without Reduction ratio, approx 247N.m with 1:4.77 Reduction ratio
Reduction ratio: 1:4.77 (as default)
Max Efficiency: pending
Continuous Battery Current: pending (72V)
Peak Battery Current: 120A (72V)
Suggest Peak Phase Current: 450A
Thermic Probe: None as default (KTY83/122 is available for mass production).
Working Temperature: pending
Single Hall Plate with waterproof connectors
16mm² Cross Section of Phase Wire (not include insulation layer)
Hall Sensor Phasing angle: 120 degree
Waterproof Grade: IP54
Color: Black
By the way, QS 1000W 90H, and 2000w 120H mid drive motors all can do customize alex to add gear and chain.
Is it possible to get the same sprockets to suit 219 chain for the 2000W mid drive? I am keen to order three motors this week.
Do you offer bulk pricing?
Is there an ebike version of the 273 v3 motor? I'm looking for a motor laced on a 19" moto rim with a chain sprocket on the side.
Enviado de meu SM-G955F usando o Tapatalk
Yes, we can provide price according to your quantity, more cheaper if more quantity.
So could you pls tell which items do you want and how many do you want?
Thank you,
Judy
E-mail: judy@tzquanshun.com
Yes, we have 4000w 273 v3 spoke hub motor for e-bike, pls see below picture and drawing
More detail, pls see this link: http://www.cnqsmotor.com/en/article_read/QS%20Motor%204000W%20273%2040H%20V3%20E-bike%20Spoke%20Hub%20Motor/260.html
The unit price is $448/pc
Could you tell below question that i can recommend you suitable winding:
1. E-bike weight?
2. Max speed requirement?
3. Voltage?
4. Climbing angle requirement?
Thank you,
Judy
Wechat: gh13797405776
DEHiCKA said:
Thanks, but this appears to be Type 1 casing. I've asked about your new Type 2 casing.
Here attach the drawing for type2, pls check.
Thank you,
Judy
  • Drawing for new 138 mid drive motor.pdf
Hi, what is the size of the shaft on the 1000w mid drive motor?
I am keen to fit a belt and pulley to drive a go kart wheel of 10 inch diameter.
Here attach the drawing both QS 1000W 90 mid drive motor single motor and assembly, also shaft drawing, pls check.
Thank you,
Judy
  • Shaft drawing中置轴90.227-80H(霍尔).pdf
  • 1000w mid drive motor single motor drawing.pdf
Dear Judy,
We bought in wheel 48V 5000W hub motor for one EV project. But we didn't want to go with Kelly motor controller because we have one requirement that Kelly Inverter cannot handle this based on our experience. So, we decided to go with Sevcon Gen4 inverter.
Nowadays, we are struggling to find true parameters of that motor. Such as inductance, phase to phase angles etc. Since we find that parameters with manually, we face some issues especially in the starting of vehicle with >%3 grade.
Can we find parameters in somehow?
Thank you in advance.
cestika said:
Dear Judy,
Could you give me picture of your motor? Especially the serial number that i can see if we can find the record.
By the way, could you tell where did you get our motor?
Thank you,
Judy
QSMOTOR said:
cestika said:
Dear Judy,
Thank you,
Judy
I sent the picture and the invoice of the motor via e-mail. We bought your motors from directly your website.
2019 QSMOTOR WCDF Hundred-Regiment Campaign
https://tzxiya.en.alibaba.com/promotionPage.html?spm=a2700.icbuShop.88.37.13ca556eNwlmB1
To express our gratefulness to all our customers, a series of promotional activities will be held in June by SIAECOSYS/QSMOTOR, which called 2019 WCDF hundred-regiment campaign.
During this time, most products include QS Motor(≥3000W), Kelly controller, Sabvoton controller, etc.. are on promotion!!!
Activity time: 17th June to 31th July 2019.6.15
Btw., from 20th June, 2019, the new Aliexpress store will be opened, it will be convenienced for customers who want to make order online.
Appreciate for all the support!
Here is the items on promotion on Alibaba, and also have Coupons you can get: https://tzxiya.en.alibaba.com/promotionPage.html?spm=a2700.icbuShop.88.37.3cdd556etdsj85
On sale price
Moreover, QS 205 3kw hub motor, 273 above 3kw hub motor, Kelly controller, KLS and KVD series controller is under promotion also. .
Restriction 20pcs per goods.
More details, pls see attachment.
Best regards.
Judy -Powered by SIA
No QS Motor, No Super EVs!
-SiAECOSYS. -QSMOTOR
-International Sales -Tel: +86 0576 88551619 -QQ: 710436216 -Skype:judy.gong5
-WhatsApp: +86 13575887162 -Email: judy@tzquanshun.com
QSMOTOR 180 9000W 90H PMSM IPM mid drive motor
For a long time, we are developing and testing our new 8000w mid drive motor, below is the result
For Motor
Item: QSMOTOR 180 9000W 90H PMSM IPM mid drivemotor
SPEC
·Motor Type: PMSM IPM Motor With Hall Sensor
·Rated Power: 9000W (18000kW peak in few seconds)
·Rated Voltage: 72V
·Speed: 4000RPM peak (basic RPM), 7000RPM with flux weakening
·Max Torque: approx 100N.m peak.
·Max Efficiency: approx 95%
·Continuous Battery Current:200 A (72V)
·Peak Battery Current: 250A (72V)
·Working Temperature: 70-130℃ , peak 180 ℃
·Single Hall Set with waterproof connectors
·Waterproof Grade: IP67
·Cooling: air cool
·Dimension: φ200X280mm
·Phase wire: 22mm²
·Insulation grade: H
·Working system: S9
·Color: Black
·N.W./G.W.: approx 25kg
·Package Dimension: pending piece
PS. For 180 PMSM motor, it’s maximum 135H 12000W motor.
The current product shell is a more industrial design, need to update the picture
Below are pictures for previous sample 180 135H mid drive motor, we plan to do some appearance updates for final sample, i will show you pictures when the sample finished.
Drawing
Here is drawing for whole 180 mid drive motor, if you need high-definition picture, please kindly ask me.
Please check the installation dimension, especially the diameter and width for threaded holes.
2.Match with sprocket SN520 13teeth, plan gear ratio 1:6.5
520-13 teeth
Test report
180 90H MAP
180 75H 7500W 99N.m
180 135H 12kw
with EM300 72V 350A, approx 102N.m peak
with EM300 82V 350A, approx 100N.m peak, 24kw peak
Application
Heavy Electric Motorcycle, e.g. Harly Scooter
E-motorcycle weight, approx 180kg+2*80kg
Speed: continuous 100km/h, peak 120km/h
Gear ratio: 1:6.5
Climbing slope: 50°@260kg
Battery: 72V80Ah
Tire: 0.6138 130/70-17
Calculations
For Controller
We suggest to choose sinusoidal wave Motor Controller EM72200SP with standards CANBUS,
EM72300P should also work (without CANBUS).
functions available for speed modes, anti-theft, cruise, reverse etc.
refer to below hyperlink.
http://www.cnqsmotor.com/en/article_read/VOTOL%20Lande%20Controller%20BLDC%20Programable%2072v%2048v%20Mid%20Drive%20Motor%20Controllers/837.html
Any needs, free to send e-mail: judy@tzquanshun.com
Overclocker said:
hi QS Motor i ordered a QS 1000W 205 35H V1 motor on aliexpress. i got this message.
also, what is the typical spoke length for 26" rim?
Thank you for your messgae, our normal spoke length for 26inch wheel is 12G 158mm
May i know your e-mail address?
Thank you,
Judy
I'm very excited for the new 9000W 180 135h mid-drive. When will it be available and is there a known price for them yet? Will they have one or more temperature sensors installed from factory?
The 9000w 180 mid drive motor is available for market, the production time is about 1 month, the unit price is $650/pc
It can match with EM72300P controller, the unit price is $558/pc, EM96300P is $578/pc
Yes, it will add temp sensor.
Sounds interesting. What is the rpm/volt, phase-to-phase resistance, and rated rpm along with the no-load current required at rated rpm? Peak efficiency would be great too.
Yes, we send is 5T 410rpm @48v, if your voltage is 69.8v, the RPM is about 597. Different controller, the data would be little different.
Overclocker said:
hi judy are you sure you sent me correct 5T winding? 5T winding should be 9.67 kv (RPM per volt)
this motor is turning at 618RPM at 69.8v. which is 8.8 RPM/volt
SPEC
·Rated Voltage: 72V
·Cooling: air cool
·Phase wire: 22mm²
·Working system: S9
·Color: Black
More information, we will post after testing.
12*3.5inch 1500W 48V 55kph BLDC E-Scooter Hub Motor Kits Power Train with EM50SP controller
It's QS electric In-Wheel Scooter Hub kits, suit for electric scooter 48V 55km/h.
One set including below kits
1. 1pcs X QS 12*3.5inch 1500W V1.12 BLDC E-Scooter In-Wheel Hub Motor
2. 1pcs X Votol EM50SP motor controller with standards CANBUS
3. 1pcs X DKD LCD speedometer with standard CAN-BUS
4. 1pcs X Z6 throttle with combination switch
Key Features
1). Simplify to make a electric-scooter. Gearbox, transmission shaft, clutch are no need. Which save space.
2). It could be installed in the rear to save more space for battery.
3). Support regenerative braking
4). High efficiency: 85~92%
Product description
1.QS 12*3.5inch 1500W V1.12 BLDC E-Scooter In-Wheel Hub Motor
Motor Type: BLDC Outer Rotor In-Wheel Hub Motor With Hall Sensor
Brand: QS Motor, QSMOTOR
Motor Design: Double axle with 12inch moped rim (integrated)
Rim Size:12x2.5inch(Narrow Tire), matched tire:90/90-12 etc
 12x3.5inch(Wide Tire as default), matched tire: 120/70-12 etc
Magnet Height: 30mm, 24 pole pairs
Stator: Steel Core
Rated Power: 1500W
Speed: 30KPH-55KPH, 48V 55KPH 670RPM as default.
Work voltage range: 48V-96V, 48V as default.
Max Torque: approx 113.0N.m
Thermic Probe: KTY83-122 (as default, optional)
Max Efficiency approx 88%
Brake type: Disc brake (as default), PCD3*80mm-M8, CB 58mm
Drop-outs: 200mm
Single Hall with waterproof connectos
6mm² Phase Wire
Color: Black (As default)
N.W./G.W.: approx 13.0/14.1kg
Package Dimension: 43cm*43cm*34cm/piece
Power train test Report:
2.Votol EM50SP motor controller with standards CANBUS
3.DKD LCD speedometer with standard CAN-BUS
It display D N R, P, S gear, and battery current X5/10
4. Z6 throttle with combination switch
With Reverse, Parking button( throttle on/off), 3 slide switch gear, s/boost button, Light and Horn.
It match with VOTOL controller well.
More details, see this link: https://www.alibaba.com/product-detail/12-3-5inch-1500W-48V-55kph_62201822570.html?spm=a2747.manage.0.0.6ef471d2VuGPpL
Thanks for all the detail on the 180 motors. The 75H looks perfect for some of my builds, but on some I'd what the higher potential of the 135H. The wide rpm range with over 90% efficiency of the 135 is quite impressive, however, I really need to use a 20-22s battery pack to take best advantage with the batteries I have available. With the wheel size I want to use the motor rpm of the 135H seems too high, requiring a gear reduction of 7:1 or greater. I want to run belt drive to avoid chain noise and need a lower gear reduction. Will these motors be available in different windings? I'd really like the 135H in a winding below 50rpm/volt like the 75H in the test reports instead of the over 80rpm/volt shown for the 135H while retaining the same or better copper fill.
For 180 motors, we will do 90H 9000W first, because it suits most of e-motorcycles, 135H suits more heavy vehicle. For this 90H, we design the shaft for sprocket with chain which will suits different tire size. For belt, it only can suit one special wheel size. But we will consider that if possible.
