Recently the man who sold me my electric motorcycle upgraded my batteries from 72v20a lead acid to CATL 72v100a lithium ternary batteries. Very happy indeed. But I am thinking of going a step forward and upgrading the QS Motor 2000w hub motor to a QS Motor 3000w hub motor for sometimes faster speed and acceleration. The current max speed I reached in ideal conditions tracked by GPS is 83.7 kmph, and usually I cannot push it over 75 kpmh. He says a 3000w motor will increase the maximum speed to around 100 kpmh.
On one battery charge on my original 2000w motor I was able to go 181.7 kilometers in setting 3 (the setting that consumes the most energy) and 246.5 kilometers on setting 2 (mid setting) before the BMS stopped the motor.
Now, I’m not a very technical person and we speak different languages but communicate through Google Translate (he’s Chinese, we live in Laos), so some things get lost in translation.
I am trying to understand that if I go the same speed with the 3000w motor as the original 2000w motor, will the same amount of battery be used/will I have the same range per charge? For example, if hypothetically I were to maintain a continuous speed of 60 or 70 kpmh with each motor, hypothetically under same driving conditions and the only difference being the motor, would I have the same range with the new 3000w motor? If not, would I lose a lot of range? I do understand that in faster speeds I will lose range, but am confused about this point.
Thank you for helping out someone who has a hard time grasping some of these concepts.
