bee
I'm starting to reach the limits of my GNG kit and would like to start planning my next mid drive bike.
I'd like to use this 24" hardtail NS Holy 2: http://www.ns-bikes.com/holy-2,54,pl.htm
I want to upgrade it with some nice suspension forks, front disc break, and a fat rear tire.
I'm not 100% sure if I want to use a hardtail bike. With my current GNG, when I open up the throttle for wheelies, the bikes rear suspension compresses quite a bit, which seems to make it harder to control. I've read on downhill/freeride forums that a hardtail is better for beginners, but I'm not sure if that advice still holds true on a bike that's heavier because of the motor. This bike will also (possibly) be capable of pretty high speeds, I'm not sure how safe I'd feel going 50mph on the horrible roads here without a rear suspension.
I plan to attach the motor in direct drive on the left side using #219 chain and sprockets attached to the disc brake mounts of the rear wheel hub.
According to http://www.electricbike.com/astro/ the 3220 peaks at 7500 RPM and produces 8hp.
The largest #219 sprocket I can find for the rear is 105T, which gives me these options for the front sprocket:
10t: Speed at 7500RPM with ratio of 10.5:1 with 24inch wheel = 82.08kph (51.00mph)
11t: Speed at 7500RPM with ratio of 9.54:1 with 24inch wheel = 90.28kph (56.10mph)
With this gearing, will I still get a lot of torque in the 0-40km range for doing power wheelies and lower speed freeride/trials type riding, or do I need a larger gear reduction for that?
Can I safely go wide open throttle from a stopped position with this gearing and send 8hp into the disc rotor mounts? Anyone know the max torque I can put through the disc rotor mounts?
Is 7500RPM/8HP the limit for this motor or can I overvolt and increase the gearing to achieve better peak performance? I'm more interested in bursts of power rather than continuous power.
What kind of controller should I use? I was planning to attach hall sensors since I read that improves low speed control.
Would regen be possible with a big motor like this? My riding style is very inefficient so it would be great to harness all that constant braking power to prolong the ride.
I still haven't found a source for the smaller #219 sprockets that will fit the 3/8" or 1/2" astro motor shaft. Any suggestions?
Thanks
Thanks
