Rix
100 TW
efMX Trials Electric Freeride said:i dont think an IGH internally geared hub such as rohloff etc would handle very much motor power for long..
and it would be an expensive replacement..
likely better to go single speed with higher power (less things to break
(do a search on here for "revolt" for some inspiration
Sowa said:So is the chain the only weak link? Can anyone confirm how much power these geared hubs will take?
I'm also fairly new with these smaller motors. Everything I deal with in the dyno lab is ~415kw. What are some good name brand motors?
Good points, I don't know what peak kw the Rolhoff hub can handle, but I am going to say not much above 2 kw. And to be successful with 2kw, probably running the smallest drive sprocket than can fit on the hub, and at least a 50T chainring up front. Rolhoff posted some data about their hubs being limited by gearing options when used on tandem bikes. Specifically restrictions on crank arm length and minimum Chainring tooth requirements. No way this hub is handling much powre over what 2 people can generate on a tandem let alone 10-14kw. Here is the link. http://www.rohloff.de/en/technology/workshop/sprocket-ratios/index.html
