John in CR
100 TW
Radial spokes always seemed wrong to me, though I lacked an explanation and I've seen a number of people say radial lacing is just as strong. Sheldon Brown's site explains it here http://sheldonbrown.com/wheelbuild.html go most of the way down to Radial Spoking. The small hub part doesn't fit our applications, but the big changes in spoke tension during braking or acceleration certainly does. I also found some motorcycle wheel info recommending against radial too.
Before those who have used it without issue step in with their anecdotal evidence that radial is ok, the physics is against it, so do you really want to recommend something more likely to suffer a catastrophic failure?
I was about to give radial a go, and now I'm glad I did some research first, and I thought I should share what I found since contrary info is floating around on the forum.
John
John
