hjns
🚴♂️ Mega poster
Some stills of my commute this morning. I will upload an edited version of the movie into Youtube later this week.
methods said:Alan B said:Modding these controllers to bypass the limits has its risks.
I take issue with the phrase "bypass the limits". ...
-methods
hjns said:Hi John,
Good idea. I like some passive methods to keep the lipo's warmer. I am hesitant to try out something more active that generates heat around lipos.....
John in CR said:hjns said:Hi John,
+1. I don't even like the sun shining on my lipo enclosures. I'll leave the cold to you guys though. Snow is for winter vacations, and I'll stick with temps always in the 20's C, IOW a nice spring day every day.![]()
I take it that you have to use spikes on your tires and all that stuff?
Stay warm,
John
John in CR said:+1. I don't even like the sun shining on my lipo enclosures. I'll leave the cold to you guys though. Snow is for winter vacations, and I'll stick with temps always in the 20's C, IOW a nice spring day every day.![]()
Stay warm,
John
MadRhino said:Rear brake doesn't need to be very powerful, especially DH when the rear is unloaded and very easy to lock.
The true advantage is modulation in those circumstances, you should be comparing models for brake pad surface size and lever adjustment options. Precise braking and independent regen button are doing miracles for the tail.
Next is custom tuned rear suspension to match the weight of your wheel.
For the front you need a lot of braking power, after all it is all the weight of the bike and yourself that is going there when you do a quick stop. Heat dissipation, modulation, system volume and piston pressure, you need them all for this one.
The vid quality is very bad, even for low resolution. Compression level too high, obviously.hjns said:...I am still not happy with the quality produced by the Youtube encoder when going full screen.
