64ragtop
I just acquired an electric trike in running condition, but with no documentation. it came with an active battery pack consisting of three 12 volt sla batteries that seems to have been created in the "necessity is the mother of invention" school of engineering. It also came with a battery pack that fits into the frame for a much neater appearance. I think the second pack was maker supplied and the first - - well....it was providing motive power.
For some silly reason mostly having to do with an air conditioned workspace - I live in Austin, Texas, and our temperatures have been flirting with the 100 degree (F) mark for about two months - I decided to try to figure out the maker supplied battery pack first. it consists of a charger port, three 6DZM-10 12 volt 12 amp hour batteries in series and an output contact set that matches contacts inside the rack the battery pack slips into, and the wiring and jumpers needed to place the batteries into a series configuration.
using an old, but trusty analog volt-ohm meter, I measured approximately 36 volts at the charger input, and the same at the output terminals. I also measured approximately 12 volts from each battery. When I attached the battery charger, however, I measured 13.25, 13.0 and 16 volts on the three batteries. Since I am not conversant with any oriental alphabets, I suppose the led changing from green to red is the expected behavior. The other led remained red, the fuse didn't blow and the charger only got s bit warmer than room temperature. I'll take all of this as "normal" until I learn otherwise.
So, first question: what do the varying voltages on the batteries while connected to the charger mean?
Second: should all three batteries in a series configuration to drive a 36 volt motor and controller be equal in amp hour ratings.
Third: any other insights and wisdom is much appreciated.
Thank you!
Thank you!
