threadjack alert!
After digesting the #s a bit further I think your going to be running into saturation issues well before the motor starts delivering 28k watts of output .... Unless you have some better laminations than typicle...thus all that extra power on the controller side will be "cushion" The motor is only going to make as much out put as it can.....the rest will just cook the windings. How fast is up to you. will be interesting to see where the bmf starts kicking in & stabilizing the set up.
I chuckle when the guys running astro motors claim 14k watts out of the 3220 (for how long? on a 4.5kw rated motor?) Just cause they read it on the data logger...The continuos rating is far more realistic for any application where you run a battery through a full cycle.
I really would love to see what these blended hubbies are capable of on a dyno once all is said & done. Swaging it, I will guess you'll peak an out put # in the 12kw range...(& the only way to measue that is on a dyno) no idea on what to call it for continuous rating....depends on the application i supose.
OT.
Farfle, show us the chips flying off the lathe on your new stator support gizmo. I wanna see what 2 slices of magic pie will do!
