Hello I have been working on converting a MTB to ebike and I have ran out of ideas on how to sort out my rear brake.
As you can see in the picture the brake adapter isn't parallel with the rotor making it impossible for the pads not to rub.
There is a 2mm gap between the adapter and the rotor at the top whilst a 1mm gap at the bottom.
For the caliper to be aligned perfectly it would have to
Sit like this obviously no good as you can't fit a bolt into the hole.
I have tried placing a small washer in-between the frame and the adapter to try and straighten it out but I then run into this problem.
As you can see the caliper is at its furthest point to the left but the rotor is pressing on the left brake pads and now looking at the picture the caliper still doesn't look straight
I'm using a 3mm anti rotation washer as a spacer on the axel. If I go any smaller the caliper hits the hub.
Any ideas please?
Any ideas please?
