Alan B said:Unfortunately the settings on each individual unit are adjustable and so they can be sensitive or not. Your rim is probably the best shot, I've seen road bikes open our exit gate with their small racing tires so the rim is close to the ground where my much larger steel rim in the same spot doesn't work perhaps because there is a lot more rubber between the rim and the pavement. Going slow or stopping with the rim in the best spot is a good thing to try.
Figure 2-9 illustrates the detection of a bicycle or motorcycle by an inductive loop. These conveyances can be modeled as a vertical conducting object relative to the plane of the loop. When the cycle travels along the loop wire, eddy currents are induced in the conducting wheel rims and frame. When the cycle is directly over the loop wire, coupling between the inductive loop and the cycle is maximized.
A vehicle undercarriage, on the other hand, is a horizontal target. As shown in Figure 2-10, the undercarriage is modeled as a conducting rectangular plate, whose width is equal to the width of the vehicle and whose length is equal to the length of the vehicle at some average undercarriage height.
A conducting mesh can be used to approximate the electrical characteristics of the continuous plate. When the mesh is symmetrically located over the inductive loop to produce maximum sensitivity, all induced internal mesh currents cancel. This results in a single induced current flowing around the perimeter of the mesh, which is equivalent to a single turn rectangular wire loop or shorted turn. The air core transformer on the right of Figure 2-10 models the coupling between the vehicle undercarriage, as represented by a shorted turn of wire, and the inductive-loop wire.
Maximum vehicle detection sensitivity is produced by a shorted turn at minimum distance from the loop wires. Consequently, the ideal inductive-loop detector has a shape that approximates the vehicle's periphery. That is, a 6- x 6-ft (1.8- x 1.8-m) square loop would be preferable to one the size of a vehicle's engine.
Because of undercarriage height, high-bed trucks are difficult to detect. Detection of these vehicles is maximized when the width of the loop is equal to the width of the truck, lane width permitting. The length of the loop should not be less than its width to avoid a loss in sensitivity.
The fingers said:http://www.themirt.com/how-it-works.php![]()
Someone on here couldn't hack one like this up? I have a mfgr's demo of something similar but have never tried to use it.
I put my steel toe boot on the loop, but with mixed results. :|
Has nothing directly to do with just mass.mikebikerad said:My steel frame e-cargo bike with large steel frame running boards has no problem opening our driveway gate using the sensor from the inside, while our titanium and aluminum frame bikes with less mass have no chance. This further supports the concept everyone is talking about mass and iron/steel.
Alan B said:The best info in the older threads here was the thought of using mu-metal to affect the pickup coil's frequency, and Richard was going to test this, but I saw no results in the thread.
Since I see no mu-metal based products in the marketplace, perhaps we can conclude that it did not work.
I hadn't heard of that before--I know that I cannot make any of the alloy bikes I have had (even a pretty heavy one that also has aluminum cargo pods and a flat rack of alloy plate with alloy flat plate sides/supports, alloy rims, etc. The only steel on it was the spokes, some nuts/bolts, crank shaft, bearings, small stuff like that.cal3thousand said:Aluminum will do it to if shaped properly and large enough. Firefighters use their ladders (which I presume aren't Ferrous) to get around gates:
http://www.vententersearch.com/induction-loop-trick/
gogo said:Found this while looking for 6V bulbs on eBay:
http://www.ebay.com/itm/Green-Light-Stuff-Trigger-Harley-Nickel-plated-/130417589489?
GREEN LIGHT STUFF TRIGGER FOR HARLEY DAVIDSON - NICKEL-PLATED
BK part number: C01000446
Condition: New
Description:
Makes the vehicle more "visible" to traffic signal detectors
Works on motorcycles, scooters, mopeds and bicycles
Simple, safe, legal and effective
Installs in seconds with no wiring
Installation instructions included
The "more effecient" model; nickel-plated
Triketech said:The vast majority of loop detectors used at intersections are capacitive systems.
How to Trigger A Green Light With Your Bike
Intersections with loop detectors that detect metal can detect bikes as well as cars. Many Pasadena intersections have these loop detectors. However, you have to position your bike wheel in the right position on the loop to trigger the green light. Here are examples of ways to use your bike to trigger the detector to give you a green light:
https://ladotbikeblog.wordpress.com/2010/11/10/anatomy-of-a-bicycle-friendly-street-loop-detectors/
Anatomy of a Bicycle Friendly Street: Loop Detectors
November 10, 2010 by LADOT Bike Blog
We’re back today with another installment of what surely is your favorite bicycle infrastructure series. Last time out we covered Traffic Diverters – the Cadillac of BFS treatments. This week we’ll look at a much smaller, but no less important, treatment in the:
Loop Detectors
Placing your bicycle correctly makes for a much more enjoyable ride
(Ed Note: Most information on Bicycle Friendly Street treatments come from the Technical Design Handbook in the draft 2010 LA Bike Plan. Though we are happy to present it in bite-sized pieces, we highly recommend you download it yourself and have a good read. You can download the Technical Design Handbook here. For a refresher on what a Bicycle Friendly Street is -sometimes called a Bike Boulevard- you can read our introductory post here.)
http://clkrep.lacity.org/onlinedocs/2010/10-2385-S2_MISC_07-11-11.pdf See loop detector: Page 76
Listed as a “Type 3” treatment for a Bicycle Friendly Street, loop detector symbols sit dead center in the range of street treatments. While we’ll go into the specifics of how loop detector symbols can be utilized in a Bicycle Friendly Street, we should first cover what loop detectors are and how they work.
Changing Lights with Loops
Loop detectors are coils of wire set into the pavement which, after they are electromagnetically triggered, alert traffic lights to change in the direction you are traveling. There’s a good amount of the hard science on the subject, which you can read more about here.
The takeaway is this: putting your bicycle over a loop detector should make the light change faster.
It's not the weight, it's the magnetic field
Interestingly, it’s not the weight of the bicycle that trips the loop detector, it’s the metal in your bicycle interacting with the electricity running through the loop detector. This does mean, unfortunately, that carbon-fiber bicycles may not have enough metal to set off loop detectors. Since 2007, California state law (with the passage of AB 1581) requires all new loop detectors to be sensitive enough to pick up bicycles......snip
