mrfeelgooddrag26
i have a some what weird idea to recharge batterys.
having 2 bikes one would be your e bike the other bike would be a modifed bicycle with a car alternator.
the way im thinking is you take a gear from a motorizied bicycle that smashes toghter on the spokes then mount the alternator in the frame. then take a gear that matches up to the 415 sprocket and mount on the alternator then run a chain and a chain tensioner just like they use on gas bicycle conversion kits. also to contain the power would be some sort of 12 volt car battery on the rear rack???. then when you ride the bicycle around your charging up your 12 volt car battery witch when full you hook into a 12 volt inverter and run your lithium charger or your lead acid battery charger.
on the flip side would it not be easier to have a solar panel and 2 12 volt car batterys and have the solar panel on the roof of your house to charge the batterys? then use the inverter to charge from the energy created by solar?
