Hello everyone,
I have been researching reliability issues related to battery systems used in outdoor environments, especially for applications such as energy storage cabinets, solar battery systems, and EV charging infrastructure.
One problem that seems to appear repeatedly in field installations is the long-term reliability of cable connections between battery modules, BMS systems, and external equipment. In outdoor environments these connections are often exposed to humidity, temperature cycling, dust, and sometimes vibration.
In some cases installers use standard industrial connectors or terminal blocks, but after several years corrosion, loose connections, or moisture ingress start to appear. When this happens the result can be increased resistance, unstable voltage readings, or even system shutdowns.
I’m curious about what types of connectors or connection methods people here have found to be the most reliable for battery systems that operate outdoors for long periods.
A few questions I’m particularly interested in:
• Are sealed connectors generally preferred over traditional terminal blocks for battery systems?
• How important is IP protection level in real world installations (IP67 / IP68 etc.)?
• Do vibration and thermal expansion cause connector failures in long-term battery systems?
• What design practices help reduce connection failures in large battery packs?
Some installers I’ve talked with say that sealed inline cable connectors help reduce moisture problems, especially in outdoor cabinets or containerized energy storage systems. Others prefer simple busbars and bolted connections to avoid additional connector interfaces.
From a reliability and maintenance perspective, I would be interested to hear what solutions engineers here have found to work best over time.
If anyone has experience with battery energy storage systems, solar battery banks, or EV battery packs operating outdoors, I would really appreciate hearing your thoughts or lessons learned from real installations.
Thanks in advance for sharing your experience.
