Ianmcnally sent me a couple of malfunctioning WattsUp units in a recent care package
http://www.endless-sphere.com/forums/viewtopic.php?p=303752#p303752; one has a display problem
and the other only reads amps, not volts (or anything requiring volts to calculate)
The latter was an easy determination as to the root cause:
but not so easy to troubleshoot. After prying the case open, I could more clearly see the problems:
Cleaning up the solder was fairly easy, as most was just cold-stuck blobs not actually melted to anything. But a few bits, including on the MCU pins, were soldered on well enough to require the soldersucker.
After removing it all, it didn't make a lick of difference to the problem.
totally open. It's supposed to be around 15Kohm reading there, and the one to it's right, based on the other WU and the functional one AussieJester had sent me a while back.
I can't actually read the markings on there, as my eyes are just on the edge of needing bifocals; my regular glasses (to compensate for my nearsightedness when I am walking around and riding and such) won't let me focus that close, but I can't see that well even with really good light for the tiny markings now. Used to be able to read the tiny tiny decals that Tamiya and such put on the military models, where a 1/4" decal could have a paragraph of text in it that I could actually read. Not anymore.
So I just started poking around on some dead boards from stuff I saved that have lots of SMT resistors in that form factor, and eventually found one whose markings appear the same as this one (based on rough shape since I can't quite see it). After about 20 minutes of fiddling around with the tiny thing, I eventually got it soldered in, replacing the open one. (after removing about a zillion solder bridges I kept making--my hands jitter too much for this stuff!).
I got a voltage reading, but totally wrong, showing 4.32V for a 39V source (one of the 24V chargers with no pack connected). I unplugged it, checked for solder bridges, ohmed out things and came up with normal readings. Tried again, and this time it gets 48.3V. :?
Oh, well, it's still got a good LCD, so I'll just transplant that over to the other one, right?
