synthrider
- Joined
- Mar 30, 2012
- Messages
- 36
Have a few things to report and maybe a question... First the report:
1) I just killed an almost new 36v10a Little Frog battery by accidentally discharging it completely... like 101% completely. They aren't kidding around when they suggest against this in the manuals. It died in the middle of my ride home, and now refuses to charge properly. I plugged it in a few hours after depleting it. Charger lit red for a baffling 2 hours, then went green. LEDs on battery indicator never turned on and it never worked after that.
I know I can probably fix it myself by testing/replacing a cell or two inside, but I am too busy/unmotivated. I'm in touch with a shop in town about doing it for me.
2) Here's the deal! The reason that happened is because the wiring got frayed inside/near the L-shaped connector that plugs from the charger to the battery, just like with a pair of old headphones. So it looks like its charging, and then there's a gust of wind or something and the connection breaks. I come back a few hours later and the light is green, so I think its good to go, when it ain't. The same thing has happened to my stock charger for the stock 24v10a. It was just annoying at first, but now its cost me a battery. Next charger I'm getting I'm going to reinforce around that connector with electrical tape or maybe even that aluminum tape carpenters use.
3) For some good news, I solved my crappy stock grips and crappy stock handlebar stem in one shot with the following grips: http://www.chainreactioncycles.com/Models.aspx?ModelID=35359. I was having a heck of a time straining my neck and back leaning forward and down to reach the handlebars, plus developing wrist problems, and the Ergon GC3 grips solved the whole business. The neat thing is they have them available in a "Rohloff/Nexus" configuration, where the left is 140 mm and the right is 105 mm (something like that), which means it fit perfectly with the stock throttle, which I'm still using. Neat.
