elo
10 µW
- Joined
- Feb 26, 2017
- Messages
- 5
Hi Jonny
I too have had different experiences in design and transformation into electric vehicles.
I would like to give you some my opinion, so in general, and discuss some Reference datas to compare our projects.
The RV-120pro is a motor designed for the RC aeromodeling, therefore has special characteristics for this use, that are:
1) The propeller requires little torque at low revs, and this coincides with little cooling at low RPM of the motor.
2) The required torque rise by increasing the rpm, but has never sharp peaks.
3) Increasing the RPM, increases the torque and therefore the current in the stator, but also increases the speed of the model and then increases the cooling of the motor.
From this short list i can deduce that, to use RC aeromodeling motors in to "terrestrial" vehicles you must take care to:
1) Run the engine at high rpm, using short trasmission rate (and this applies to all air cooled engines).
2) Consequently use voltages the highest possible, and currents relatively lower.
3) Cool with an external source the motor (air and/or water) that cool it even at low RPM or even when stationary.
I have in the garage a bike that uses a chassis similar to yours, then i would imagine that it also has a base weight very similar.
On this bike (is that of my Avatar) i mounted a motor with nominal 7.5Kw (PERM Motor PMG132) at 3400rpm and with 20.5Nm nominal.
What is interesting is that to obtain the best performance, in Off-Road, i had to put a rate transmission of Z12/Z72.
The same rate we used on the motocross prototype "ROBO Stone 1.0" that uses a motor with 30KW and true 80nm peak.
I do not know if the rate that you are using is the definitive one, but it seems to me much longer than the engine can withstand a 6Kw (?) motor.
Here is instead a youtube channel that speaks of some electrical trial.
https://www.youtube.com/watch?v=S5U3XrdK6Ro
Regards
Regards
