I have a complete Currie kit with 24v 450w motor.
I want to modify the kit to turn a crank on the left side of the bike.
I am worried that it will turn the cranks too quickly.
It will be too quick even with a 53 tooth chain ring and a 13 tooth freewheel.
The 36v version of the motor has the same output shaft speed as the 24v motor.
The idea is to run a 36v motor on 24v to slow down the output shaft speed.
Can it be done?
In case you were wondering, I'm working on a freewheel adapter for the Currie D-shaped
motor shaft.
If you have any ideas about this I'd like to hear them.
Can it be done?
motor shaft.
