You can run the packs in parallel. Just get the voltages really close before connecting.
I have a similar setup on my Sur-ron. Two packs, each with their own BMS, in parallel. One BMS is a "single port" so it can protect during both charge and discharge. The other pack as a "two port" BMS and I charge through that one.
It's good if the two packs are very close in terms of sag. If one pack is a lot stiffer, it will do more of the work during high loads and the other pack will have to shuttle some charge during light load. You want to avoid a lot of current passing between the packs as this is lossy and generates heat. If the packs are identical, they will share the load evenly and there should be virtually no charge passing between packs.
The setup has worked out very well and I have quite a few rides on it. Not only does it double my range, but I can pull 2x more current without overheating anything.
