Hello, I am planning to build an ebike with a Sabvoton 7280 controller with a custom 20s6p battery (Samsung 50S) and I am not entirely sure how I should go about wiring the BMS terminals to the controller ring connectors. Should I use male and female connectors to separate the battery from the controller, and if I do, how do I connect my controller to XT150s?
https://www.aliexpress.com/item/1005005278036671.html - I found these on AliExpress, but I'm not entirely sure if they're the right connectors (e.g. if they would fit on the Sabvoton controller and if they are rated to handle the current), if they are, can I just solder my XT150 female wire to this and connect it to the controller?
Any help is appreciated, thanks!
