safe said:
Seems that you can only really expect about 3,000 miles out of a set of SLA's before you begin to have to think about replacement.
That's what the 'smart crowd' has been trying to tell you all along. 8)
If you recall this prediction to your drunken boast;
Toorbough Ull-Zeveigh said:
safe said:
It would be great to get 10,000 miles out of the batteries if that's possible.
"Dreaming is free."
- Deborah Ann Harry
http://endless-sphere.com/forums/viewtopic.php?f=7&t=857&p=23347
10,000 miles... that fibreglass resin is really wicked stuf!
So what have you learned from this?
I'll tell you what I think & sorry if it sullies your precious thread.
I think xyster was right when he tried to warn you that discharging to 12.0V is
not shallow.
xyster said:
12.0 volts is not shallow.
(from same thread as above)
Also the main reason I was following your SLA saga was that my PbAs always died prematurely from sulphation whereas you had meticulously taken steps to prevent that (with only the one slip-up in that regard) & was curious to see how much it improved the lifespan or if it even made any difference.
So the big thing I learned, actually more like confirmed what I suspected is that sulphation is just one half of the one-two life-killing combination punch that will getcha one way or the other.
The other major flaw that drastically restricts the calender life is grid corrosion, so even if you do everything right, which you nearly did, the plates will still fall off as their support structure deteriorates & this trumps any & all efforts to maximize their lifespan.
Gee, who would have thought that dipping metal into a corrosive acid would dissolve the battery's internal structure?
That is one of the 'innovations' behind the Firefly/Oasys battery, that they simply replaced the vulnerable metal bits with graphite to support the plates so that they won't deteriorate with age.
Wow! That was reel difficult to figure out & it only took over a hundred years of the same old same-old to do it because it's more profitable to have batterys that wear out & require regular replacement.
That's the beauty of capitalism that you so admire, so I hope you learned something there.
With the other Firefly off-the-shelf innovation of using foam microcell plates I am even so optimistic that lead-acid could finally be a reasonable alternative now that I'm eager to vote with my money if they ever show up here.
The other thing I hope you learned but I doubt your ego will allow it is that this one test was worth 10,000
of your opinions.
I hope you learned that there are other intelligent & even not so intelligent people in the world besides yourself that shouldn't be so readily dismissed when trying to help you & the thing that counts way more than intelligence is someone's direct hard won personal experience that they've taken the time to share with the rest of us.
