should it not be logical that as example Samsung 30Q gets hotter as 25R at same continuous discharge rate because 30Q has more energy in it therefore the discharge time and energy turend into heat is more. or do i miss something?
This is a good point maddin.madin88 said:i believe most people will not push even these high power cells at theire limits because who really builds an e-vehicle with only 10min travel time?
if i look at my bikes i have on one 12P 25R and the other has 11p 25R. another has 9P VTC4.
even if i set Max-E controller to max amps it would only be 17A for 9p VTC4 and 13,5A for 11p 25R per cell - much more on peak side than continuous. During ride i have an average consumtion of about 3kw (usually 70-80kmh) what means about 3,5A per cell continuos. These cells will laugh over these currents and hopefully will thank me with high lifespan^^
ridethelightning said:Its more p all the way im afraid allex
if only i could stuff another p or 2 into the nyx frame, but its actually not quite as big as i thought.
I think 12p 25r should be good for some punch, but the 20% extra capacity is tempting with the 30Q. i just dont want to compromise on that wingsuit feeling
I doubt you would see any difference in sag, ....and certainly hard to measure accurately.ridethelightning said:.
i will either get the samsung 25R or 30Q in 20s12p i think, but The deciding factor will be the sag at high amps, which im still trying to get info on....
Hillhater said:I doubt you would see any difference in sag, ....and certainly hard to measure accurately.ridethelightning said:.
Once you have so many cells in parallel, the IR is barely any different between the packs ( less than 0.5 mohm), and even if the 30Q was a 10P pack to give the same capacity, the IR difference is still much less than 1 mohm
ridethelightning said:I think the 30Q is better then 25R. Same resistance more cap.
Downside is cost(quote)
I got a quote from a chinese supplier it was around $3.1percell forqty 10,000 shipped by sea.ridethelightning said:well looks like ill get 244 30Q cells, good for 22s12p.
was thinking 20s might be better for the max-e controller at high phase amps, but if i get 22s and only charge to 88v,4.0v/cell, should get great cycle life from them, and there is the extra capacity with 22s too.
seems like the 30Q go for 3.5usd quite often on aliexpress sites, so ill try for a better price with evva.
I wouldnt trust those other aliexpress sites in a flip
btw. perhaps the 30Q should be added to the title post?
bellfador said:In cold conditions internal resistance of 30Q is higher from 25R. When I get 30Q will be able to tell this with certitude.
Charts:
https://www.dropbox.com/s/x6514tdp5...2500mah 18650 constant-current tests.bmp?dl=0
https://www.dropbox.com/s/nle8ol3eq...q 15a 3000mah constant-current tests.bmp?dl=0
Charts:
okashira said:I got a quote from a chinese supplier it was around $3.1percell forqty 10,000 shipped by sea.ridethelightning said:well looks like ill get 244 30Q cells, good for 22s12p.
Where are you seeing 3.5 per cell? I don't see anything remotely that low on aliexpress
ridethelightning said:okashira said:I got a quote from a chinese supplier it was around $3.1percell forqty 10,000 shipped by sea.ridethelightning said:well looks like ill get 244 30Q cells, good for 22s12p.
seemed to be pretty common price on aliexpress. ill find the links when i get a moment.
It will be useful to know if the low temp performance is different.bellfador said:In the beginning of discharging charts (near 3.8-3.7 V) temp is still low and difference in voltage is bigger.
ridethelightning said:interesting... how cold are we talking?
sorry if you have alredy said and i missed it.
Hillhater said:It will be useful to know if the low temp performance is different.
but on those charts 3.8 volts is only relavent at light loads (<10A) and even then only for the first minute or two of use ( leass than 10% of capacity )
..But for most of us, operating in normal temps, and at typical usage situations over the other 90% of capacity, ..those charts show the 30Q has less voltage sag ( at 20Amps and 1.0 Ahr usage ), and even a lower IR ( 15mohm vs 17 mohm ) at its best.
But again, the differences are small and once a few cells are paralleled into a pack, sag and IR would be very similar.
?? Im Surprised you think that.bellfador said:......Usually Internal resistance not changed in range 5% - 80% of capacity........
