Indeed each samsung INR18650 25R is capable of ~35A amps continuously, but in this case the voltage drops ~0.9V respect 1A discharge.
So 120A peaks are completely possible (even till 210A) but not very efficiently of course, heat will be heavily noticeable.
each time you reach 120A discharge, each cell push 20A with a ~0,7V drop. with a considerable amount of heat produced by each cell.
Although the heat generated, this cells are prepared for that, so it will work within you peaks needed
