i think you are the one who lost itsn0wchyld said:sorry mate you got halfway through being right, then lost it again...
" Latter would be the better choice for performance per costs and system efficiency (less losses over phase wires)"
assuming you change battery voltage and controller accordingly, and all other wiring remains the same, yes... but the difference will be pretty minor in practice.
since P loss = I² x R it will not be only minor in practice! ähmm what do we call minor? Is it a half percent ot 2 or 3?
at twice the current we would need to lower resistance by 4 times (not only half like some may think) for same losses. where is such controller?
teslanv and i have lots of different motors, we build bikes in practice and we know what we talking about. with the simulator it now is twice confirmed that theory is one thing and praxis another.
you may have misunderstand what i was trying to point out or maybe i have not write it that understandable." And it is not the same if a controller works at 50% PWM (high kV with limited speed) or 100% (without speed limit). Consumption during acceleration (top end) is different, the 100% PWM system has higher efficiency because no additional step down losses."
Nope. sorry, but if you vary the voltage and current by the same ratio as the change in KV, then the duty cycle at a given speed/power demand will remain the same, as both motors will be spinning at the same % of their no load speed, with the same back EMF (as a % of pack voltage) same (relative) resistance and inductance. if your just comparing a high kv and low kv motor with the same battery/controller combo for each then yes, it'll have a small difference. again however you're unlikely to notice it unless the controller is struggling with the high kv motor's R and L.
"Consumption during acceleration (top end) is different, the 100% PWM system has higher efficiency because no additional step down losses."
Nope, it'll be the same, as each controller is stepping down the same relative voltage, to the same relative phase voltage, in order to generate the same phase current, and thus the same motor torque (and same motor heat). Again however if your using the same controller and battery for each motor there will be a small difference, but again, this will be small.
i was talking about differences between assumed System A [18kV motor, 80V, 50% speed limit] and System B [9kV motor, 80V, 100% speed]
system A will have much more top end acceleration, and even if you would lower controller and phase wire resistance of the 18kV System (by 4 times!!) it still would be a bit less efficienct because step down conversion creates losses.
this scenario was mentioned earlier in this thread or in another one so i wanted to show this up. it is a great idea if someone wants to have later the option for higher top speed, but it is not the same thing.
As has been stated repeatedly, there's no difference in heat generation between a low and high kv motor for a given torque output.
However, in NONE of these situations will the motors torque per unit heat change.
it cant be escaped... motor continuous torque is the same for any kv (well not quite, but the difference is so small you'll never notice outside of a lab).
YES YES, i think most of us reading this thread have got it^^
the problem is if we consider about the total drive system - with currently available components, and we should do this, than torque, performance and efficiency is different.
